[Gdal-dev] Re: Very odd problem SWIG & PERL
jolma at cc.hut.fi
jolma at cc.hut.fi
Sun Oct 23 12:52:59 EDT 2005
I hope there is no problem exposing this to the gdal-list. The summary is: when
working with gdal+swig/perl always use "my" or explicitly undef any gdal objects
you have.
Look at http://mailman.cs.uchicago.edu/pipermail/swig/2001-April/002424.html
and the resulting thread. That's rather old but it seems there still isn't any
solution to this in swig/perl.
... or this is what I think this is, after poking around with Devel::Peek
Ari
On Fri, 21 Oct 2005 10:55:15 -0500 Kevin Ruland <kruland at ku.edu> wrote:
> Ari,
> I've cc'd Ethan (irc westside) just so he knows we're trying to do
> something about this.
> I've reduced the buggy example to much less:
> #!/usr/bin/perl
> use ogr;
> $input = ogr::Open('./gdalautotest/ogr/data/poly.shp');
> $in_layer = $input->GetLayerByName('poly'); # Ref line 1
> $driver = ogr::GetDriverByName( 'MapInfo File');
> #my $ot; # Ref line 2
> $ot = $driver->CreateDataSource('./myoutput');
> print "After CreateDataSource\n";
> #$ot = undef; # Ref line 3
> print "Exit\n";
> I slipped a printf in the perl/ogr_wrap.cpp file in the XS(
> _wrap_delete_DataSource) which did this:
> printf( "Calling _wrap_delete_Datasource %x\n",arg1);
> and reinstalled the perl module. I did this to demonstrate what's
> going on.
> The scripts creates two different DataSource objects: $input and $ot.
> We expect that both of these will be deleted when the program exits.
> However, if you execute the program as it's written (I retyped so there
> might be some typo's), you will notice that only one DataSource is
> deleted ($input).
> If you rerun with either Ref line 2 or Ref line 3 uncommented, then you
> will see the second destructor getting called. Ref line 3 is pretty
> obvious because it immediately removes the reference and forces garbage
> collection. I am uncertain why Ref line 2 corrects the problem.
> The most interesting thing I discovered is if you comment out Ref line
> 1
> (and leave 2 & 3 commented out), then you will also see both
> destructors
> called.
> I've duplicated this exact same program in the python bindings and it
> works as expected reguardless of which lines are commented in and out.
> I attempted to create a test swig .i file which does not use gdal/ogr
> which replicates this problem but I have not yet been able to
> reproduce.
> There might be some kind of memory corruption going on. I've instered
> a
> bunch of diagnostics in both ogr.pm and ogr_wrap.cpp and see wierd
> things.
> Kevin
> Ethan Alpert wrote:
> >Since I'm completely dumbfounded by the following problem I reaching
> for
> >straws in the hopes someone has had something similar happen.
> >Here's some code that uses a swig generated module (hope the formating
> >works):
> >#!/usr/bin/perl
> >use ogr;
> >$input = ogr::Open('./gdalautotest-1.3.1/ogr/data/poly.shp');
> >$driver = ogr::GetDriverByName('MapInfo File');
> >#my $ot = $driver->CreateDataSource('./myoutput');
> >$out_layer = $ot->CreateLayer('out',undef,$ogr::wkbPolygon);
> >$in_defn= $in_layer->GetLayerDefn();
> >for($i=0; $i < $in_defn->GetFieldCount(); $i++) {
> > $col = $in_defn->GetFieldDefn($i);
> > $out_layer->CreateField($col,1);
> >while($feat = $in_layer->GetNextFeature()) {
> > $tmp = $feat->Clone();
> > $out_layer->CreateFeature($tmp);
> >$out_layer->SyncToDisk();
> >This code produces bogus output. However if I remove the comment and
> >comment the line above it the code works. Now clearly this is *bad*
> perl
> >but the fact that using "my" in one place fixes it confuses me.
