[Gdal-dev] how to calculate needed mem?
Frank Warmerdam
warmerdam at pobox.com
Tue Oct 25 18:11:19 EDT 2005
On 10/25/05, Matt Wilkie <matt.wilkie at gov.yk.ca> wrote:
> Hi, is there a rule of them I can use to calculate how much memory will
> be needed for gdal_merge operations?
> My current method of adding more tiles onto the input queue until I get
> "MemoryError: can't allocate memory for array" is a little wasteful and
> time consuming...
Matt,
The amount of memory used by gdal_merge.py is supposed to be
proportional to the size of the largest input tile, not the output mosaic.
> Or maybe it would be better to ask if there some way of doing things in
> pieces, not loading the complete extents into ram at one time?
It would be better to use gdal_merge.py to create the output file using
the new -createonly flag, and then use gdalwarp to actually mosaic
the images in. Gdalwarp does sensible things about memory.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
