[Gdal-dev] gdal-grass plugin rpm
Wed Oct 26 10:30:41 EDT 2005
On 10/26/05, Otto Dassau <dassau at gdf-hannover.de> wrote:
> Hi,
> I (tried to) built a current gdal-grass plugin 1.3.1.1 as RPM and defined the
> PREFIX as:
> %define _prefix /usr
> When I install the package the support is missing:
> of course it works linking /usr/local/lib/gdalplugins to /usr/lib/gdalplugins,
> but that's not a real solution -  guess. Hopefully someone has an idea how to
> fix this problem.
Otto,
If GDAL is configured to install in /usr instead of
/usr/local then the GDAL_PREFIX macro in gdal/port/cpl_config.h
should be /usr and gdaldrivermanager.cpp should look in
/usr/lib/gdalplugins instead of /usr/local/lib/gdalplugins.
You might want to look into whether GDAL was built right.
Best regards,
