[Gdal-dev] Read/Write Oracle Spatial
Thu Oct 27 09:44:17 EDT 2005
On 10/27/05, Hallgren Johan E <jhhal at wmdata.com> wrote:
> Thanks for all the assistance.
> My SetFeature problem was probably caused by the bad geometry handling in the code. It's solved now but there is still two functions a have isolated but problems remain.
Johan,
Excellent.
> When updating a field I use a function SetField and it just don't work. It will crash on that call.
I suspect this problem is a C# swig binding issue.  You should
likely file a bug on it.
> The other function is DeleteFeature. The problem is the same, it just don't work and crash on that call.
I have reviewed the code and I see there is no implementation
of DeleteFeature() for the OCI driver.  I have committed one in
CVS and would appreciate it if you could test it.  I should add
I haven't been able to even try compiling it since I am not booted
into the system with oracle at this time.
Best regards,
