[Gdal-dev] SHP <-> DGN
Mon Oct 31 09:33:31 EST 2005
On 10/31/05, Mateusz Łoskot <mateusz at loskot.net> wrote:
> Hi,
> What is the state of the OGR regarding conversion between
> ESRI Shapefile and DGN. Is such conversion possible?
Mateusz,
Yes, you can convert shapefiles to DGN files.  Attributes
will generally be lost but simple point, linestring and polygon
geometries should translate well.  I'm not so sure what happens
to polygons with holes when converted to DGN.
Best regards,
