[Gdal-dev] SHP <-> DGN
Wim Blanken
w.blanken at geon.nl
Mon Oct 31 10:14:48 EST 2005
Hi Mateusz,
Add on for the remark Frank made...
Just to let you know OGR only works with version 7 and not with version 8
DGN files as far as I know..........
Regards,
Wim Blanken
The Netherlands
----- Original Message -----
To: <gdal-dev at lists.maptools.org>
Sent: Monday, October 31, 2005 3:12 PM
Subject: [Gdal-dev] SHP <-> DGN
> Hi,
> What is the state of the OGR regarding conversion between
> ESRI Shapefile and DGN. Is such conversion possible?
> Cheers
> Mateusz Łoskot
> http://mateusz.loskot.net
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
