[Gdal-dev] Problem compiling Mapserver against GDAL with ECW sdk undefined references
James Browne James.Browne at liu.edu
Mon Oct 31 18:12:35 EST 2005
Hi all,
   Usually an undefined reference  is from a library path problem of version problems with header files. I think that I have double checked for them. GDAL command line utilities find the new ECW libraries and they seem to find each other. Trying gdal-config --libs returns the expected value.
   But when I compile Mapserver 4.6.1 against GDAL 1.3.1 that uses the latest source for ECW SDK 3.3 and even try adjusting mapserver's --prefix --libdir configure options, I still get the following errors (abbreviated series)
user: undefined reference to Inside
user: undefined reference to Case
user: undefined reference to Cut
user: undefined reference to Ensure
user: undefined reference to Accused::Set()'
user: undefined reference to Finished::Resume()'
user: undefined reference to Clothes
user: undefined reference to `CNCSThread::GetStats()'
etc.
   Does anyone have any ideas?
   Thanks
          Jim
