[Gdal-dev] New Resampling Algorithm
Julien Demaria
dem at acri-st.fr
Fri Sep 2 06:44:33 EDT 2005
I want to implement an utility to reduce resolution of an image by
averaging all input pixels contributing to one output pixel,
and I need use exactly the real contribution of each input pixel (may be a
part of it if it is at the border of the input computed window
corresponding to the output pixel coverage).
I've taken a look on the GDAL Warp API and the GDALWarpKernel class, to
know if I can implement this as another resampling algorithm, as bilinear
or bicubic,
but I'm not clear about the input pixels contribution : can I know in the
resampling algorithm what are inputs pixels corresponding to one output
pixel and how they contribute ?
I understand the density concept (float *
GDALWarpKernel::pafUnifiedSrcDensity) is related to this, but not for one
pixel, it is for all the chunk, isn't it ?
Do you think I can/should implement this algorithm as another resampling
algorithm of the Warp API, or I've to develop a specific tool ? (note
reprojection in't essential for me)
Thanks in advance for help,
Julien
