[Gdal-dev] Merging really large images to one huge
Ken Boss
Ken.Boss at dnr.state.mn.us
Fri Sep 2 10:34:57 EDT 2005
>>> "Morten Nielsen" <mn at blominfo.dk> 9/2/2005 5:03 AM >>>
Hi there
I'm trying to merge some large tiles (~5gb) to one big image (~30gb)
using gdal_merge.py, before I can compile it to ECW.
Here is what happens, when only merging just two of the tiles:
D:\>python "c:\Program Files\FWTools0.9.9\bin\gdal_merge.py" -o 6220.tif
6220_1.tif 6220_2.tif
File "c:\Program Files\FWTools0.9.9\bin\gdal_merge.py", line 468, in ?
fi.copy_into( t_fh, band, band, nodata )
File "c:\Program Files\FWTools0.9.9\bin\gdal_merge.py", line 285, in
copy_into
nodata_arg )
File "c:\Program Files\FWTools0.9.9\bin\gdal_merge.py", line 118, in
raster_copy
t_xsize, t_ysize, t_band.DataType )
File "C:\PROGRA~1\FWTOOL~1.9\pymod\gdal.py", line 845, in ReadRaster
buf_xsize, buf_ysize,buf_type)
MemoryError
The tiles are spatially adjacent.
Any ideas are appreciated.
Best regards
/Morten Nielsen
Morten--
I think the problem here is that gdal_merge.py reads the entirety of each input file into memory before writing it to the output file. Frank has recently added a -createonly switch to gdal_merge that will simply initialize the output file, allowing you to then employ the gdalwarp utility to mosaic your inputs into that output file. See http://lists.maptools.org/pipermail/gdal-dev/2005-August/006221.html.
Another approach might be to skip the physical mosaicking of your inputs altogether, creating a VRT file to describe the mosaic instead, and then using that as input to gdal_translate to create your .ecw output. I have successfully used this approach to create ~175000x225000 RGB ecw mosaics, but trying to push much beyond that has led to memory errors as well.
Gabriel Ebner posted a modified version of gdal_merge that will output VRT files a while back. You can find it at http://lists.maptools.org/pipermail/gdal-dev/2005-May/005691.html.
HTH,
--Ken Boss
MN DNR Forestry
