[Gdal-dev] Importing VMAP0 into PostGIS database;
Martin Spott
Martin.Spott at mgras.net
Tue Sep 6 03:40:48 EDT 2005
Frank Warmerdam wrote:
> Are you getting an error message output? If not, it may be that
> the VRF driver doesn't even realize it is doing something wrong.
This could actually be the case: The v0noa is the only one of the four
datasets that contains uppercase letters - but apparently this affects
only a minority of the layers. I'll change that and redo the test.
Cheers,
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
