[Gdal-dev] Transforming an ogr layer
Ari Jolma
ari.jolma at tkk.fi
Wed Sep 7 08:34:40 EDT 2005
Through some experimentation I managed to transform a layer (sorry, Perl
code, but should not be much different from Python)
# the layer I'm going to tranform does not have a spatial reference
$osr_from = new osr::SpatialReference;
$osr_from->SetWellKnownGeogCS('WGS84');
$osr_to = new osr::SpatialReference;
$osr_to->ImportFromEPSG(3035);
$ct = new osr::CoordinateTransformation($osr_from,$osr_to);
# working in this directory
$datasource = ogr::Open('/home/ajolma/proj/clime/lakes/',1);
if ($datasource) {
# existing layer, a shapefile of polygons, one datafield
$layer = $datasource->GetLayerByName('lakes');
# a new layer, similar but new spatial reference
$new_layer =
$datasource->CreateLayer('lakes_t',$osr_to,$ogr::wkbPolygon);
for $i (0..$layer->GetFeatureCount()-1) {
# this sequence was a bit hard to get right...
$feature = $layer->GetFeature($i);
$geom = $feature->GetGeometryRef();
$geom->Transform($ct);
$new_layer->CreateFeature($feature);
# save, this is needed
$new_layer->SyncToDisk;
Works fine for the vertices but the "name" field is lost from the
feature and instead there is a new one FID of type Real with seemingly
integer value. How do I make the feature not loose its existing field?
I'm sending this to the list also in the hope of generating some
documentation :)
Ari
Prof. Ari Jolma
Kartografia ja Geoinformatiikka / Cartography and Geoinformatics
Teknillinen Korkeakoulu / Helsinki University of Technology
POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
