[Gdal-dev] gdal memory load
Frank Warmerdam
fwarmerdam at gmail.com
Mon Sep 12 22:43:05 EDT 2005
On 9/12/05, Marco Vieira <marco_vieira at uk2.net> wrote:
> free command before gdalwarp:
> total used free shared buffers cached
> Mem: 906736 194520 712216 0 10520 98032
> -/+ buffers/cache: 85968 820768
> Swap: 2249060 0 2249060
> free during gdalwarp:
> Mem: 906736 902752 3984 0 1364 746280
> -/+ buffers/cache: 155108 751628
> Swap: 2249060 716 2248344
> free after gdalwarp:
> Mem: 906736 845860 60876 0 1052 751748
> -/+ buffers/cache: 93060 813676
> How can I flush memory cached by gdal lib (specially after mapserver
> requests)?
Marco,
I am not aware of significant memory leaks in GDAL and in any event,
once an application finishes all memory used by the process is returned
to the operating system. I am no whiz at understanding the output of
the free command, but I read the above as indicating that "cached" went
from 98032 to 751748. It seems to me that gdalwarp accessed files on disk
and the operating system has kept these in cached in RAM after the
program finished. This does not seem like a problem at all.
For instance, I got this free report on my system.
warmerda at gdal2200[253]% free
Mem: 1036816 542456 494360 0 252 66812
-/+ buffers/cache: 475392 561424
Swap: 1228964 46768 1182196
I then ran the command "cp gtopo.tif gtopo2.tif" and then free again and
got:
Mem: 1036816 649464 387352 0 372 173564
-/+ buffers/cache: 475528 561288
Swap: 1228964 46764 1182200
As you can see the "cached" number when up quite a bit, but the
free number when down. That is just because the operating system
kept gtopo.tif and gtopo2.tif in it's RAM cache.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
