[Gdal-dev] OGRGeometry::Distance
Mon Sep 19 09:38:30 EDT 2005
On 9/19/05, Ari Jolma <ari.jolma at tkk.fi> wrote:
> It might be confusing to document the "intermediate" C/C++ API, which is
> between GDAL C++ and the swig-based language bindings, if that's what
> you mean. I mean from the users' point of view. However, all the
> swig-based language interfaces should be as similar as possible (or at
> least implement the common base), but I'm not sure if their docs can be
> based on some common meta information. Matthew, I wrote initial docs for
> the swig/Perl bindings, they at least list all existing methods, I don't
> know if they are on the cvs yet. Frank, thinking about this, I may want
> a cvs commit rights to update and maintain these docs.
> Frank mentioned somewhere that the files in cvs can be seen on the web
> but I didn't find a link on gdal.maptools.org?
Ari,
The current CVS source code (well updated at least daily)
can be found at:
  http://www.gdal.org/srctree/
On the general issue of script bindings, I find it hard to imagine
that we have the manpower and dicipline to keep several different
sets of language bindings up to date.
Best regards,
