[Gdal-dev] GetGeometryRef in scripts
Kevin Ruland
kruland at ku.edu
Tue Sep 20 14:17:44 EDT 2005
Frank,
Hopefully you know where I'm comming from right now.... memory control
in script land. I am unfortunately confused a little. There are some
methods which I'd like to have clarification on.
Feature::GetGeometryRef
Feature::SetGeometry
Feature::SetGeometryDirectly
Geometry::GetGeometryRef
Geometry::AddGeometryDirectly
I roughly understand the difference between SetGeometry and
SetGeometryDirectly in the latter assumes ownership of the Geometry*
argument and the former executes some clone process.
Is this additional complexity required in scripts? Can we get by with
only SetGeometry?
What is Geometry::GetGeometryRef()? How would it be used?
Charlie indicates the Geometry object returned by
Feature::GetGeometryRef is owned by the the Feature object. Would it be
ok to change this from it's current implementation:
return OGR_F_GetGeometryRef(self)
To a method which returns a clone whos memory is managed by the script,
OGRGeometryH g = OGR_F_GetGeometryRef(self)
return OGR_G_Clone( g );
What about the two different versions of AddGeometry?
Thanks a bunch.
kevin
