[Gdal-dev] GetGeometryRef in scripts
Frank Warmerdam
warmerdam at pobox.com
Tue Sep 20 20:09:09 EDT 2005
On 9/20/05, Kevin Ruland <kruland at ku.edu> wrote:
> It seems, if the script bindings operate on the GeometryGuy (instead of
> OGRGeometryH), we can drop the distinction between the SetGeometry &
> SetGeometryDirectly and have the wrapper function determine which method
> to envoke. Of course, the method is determined by which of the parent*
> pointers is populated.
Kevin,
I don't really see that this is practical. Even if we have a "free"
geometry we don't know that we ought to use SetGeometryDirectly()
since we don't know whether the script will continue to use the
geometry reference later.
> I believe a strategy like this would hide the troubles of passing the
> wrong kind of Geometry into the wrong method, and at the same time
> provide for maximum efficiency. Yes there would be code overhead to
> provide the safety -- extra tests, more complex implementation of
> constructors (Clone etc).
> Also instead of using OGRFeatureH, we would have to add some reference
> counting for the handle in order to allow for chained calls.
I am depressed by this whole concept of bending over backward
to support chaining. I seems wrong to do all this backward referencing
of objects and I feel like it will one day make us all sorry.
However, I leave it in your hands.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
