[Gdal-dev] GetGeometryRef in scripts
Frank Warmerdam
warmerdam at pobox.com
Tue Sep 20 21:06:20 EDT 2005
On 9/20/05, Kevin Ruland <kruland at ku.edu> wrote:
> The current swig bindings have some short falls but I do believe they
> are fairly useable provided the developer follow the guidelines of the
> underlying C++ library. The rules in a nutshell are:
> 1) you must maintain a handle to the Datasource as long as you are using
> objects from it (with some exceptions such as XXX). If the Datsource is
> destroyed, developer pays for all damages.
> 2) Geometries returned by GetGeometryRef() become stale when its parent
> dies.
> 3) FieldDefn must have their parent FeatureDefn alive.
> I might have these wrong - the whole situation is rather confusing to me.
Kevin,
I believe your summary is correct.
> The only thing which is certainly a problem are bindings for gc
> languages. Even if the developer maintains good habits, the gc might
> still collect the trash in the wrong order.
I'm not sure why it matters what order things are destroyed in as
long as you hold a reference to things till you are done with them.
> There are a couple of ways
> to mitigate this: We could adopt a "no-fail" destructor strategy. That
> is ensure that under no circumstances will destructors being called in
> the wrong order cause troubles. Quite frankly I don't know how this can
> be done.
Perhaps you could clarify where we have problems with gc
languages. I *feel* this isn't a problem, because language
variables that reference objects should not need to do anything
at all for objects they don't own. So, for instance, a reference
to a geometry that is owned by some other object does not need
to do any work at all in it's destructor other than check it's
"owned" flag.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
