[Gdal-dev] Maps in PDA
Rich Signell
rsignell at usgs.gov
Thu Sep 22 10:43:11 EDT 2005
Gdal gang,
Here's a WMS client that works on any Java capable (MIDP 1.0/CLDC 1.0) cell
phone or PDA
http://www.skylab-mobilesystems.com/en/products/j2me_wms_client.html
-Rich
Frank Warmerdam wrote:
> On 9/22/05, Hallgren Johan E <jhhal at wmdata.com> wrote:
>>The problem is that I don't think it can run on
>>a PocketPC without recompile everything. My next issue was to figure out how
>>difficult it could be to recompile MS and all is parts to the PDA
>>environment, and my answer was that it's difficult. Beside that I don't know
>>if the MapServer solution for displaying maps in a PDA is optimal, I think
>>the aim with MapServer was to create maps on the internet and not
>>running as a single desktop app.
> Johan,
> I know there are a few folks who use MapServer as the rendering
> core for desktop display, though it is quite a bit of work to repurpose
> it that way. But the bigger issue is that porting MapServer and all
> it's dependencies to WinCE is likely to be a substantial job. The
> work Mateusz is doing on GDAL should be helpful, but that still leaves
> alot of libraries (GD, and freetype at a minumum) plus MapServer
> that would need to be ported to WinCE. Not a small task I think.
>>Next I found the work Mateusz Ùoskot is doing to porting GDAL to the Windows
>>CE environment, that's great. Could GDAL be the solution for me? It raises
>>some new questions:
> Well, GDAL would give you a mechanism for reading raster and
> vector data.
>>· It's not my dream to build logic for symbology and classification.
>>Is there any support for symbology and classification in GDAL?
> No, GDAL and OGR do not address presentation rendering,
> symbology, etc.
>>· Are there other options for my PDA issue I havent't found yet?
> I'm afraid I don't know what is available for WinCE or other PDAs.
> I would suggest you do some google searches for available toolkits.
>>· Is it possible to compile MapServer for Windows CE?
> Beyond the effort to port these things to WinCE, the othe issue
> to keep in mind is that MapServer and supporting libraries are not
> necessarily designed for the tight memory conditions of a PDA.
> Something designed with the PDA environment in mind is likely to
> be less resource intensive.
> Hopefully others will have more useful suggestions than me!
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Richard P. Signell
U.S. Geological Survey Phone: (508) 457-2229
384 Woods Hole Road Fax: (508) 457-2310
Woods Hole, MA 02543-1598
