[Gdal-dev] Re: Maps in PDA
Frank Warmerdam
warmerdam at pobox.com
Mon Sep 26 00:15:20 EDT 2005
On 9/25/05, Charlie Savage <cfis at interserv.com> wrote:
> Hi Frank,
> Quick question on process/protocol when you get a chance (no rush).
> I found a fairly severe bug in the postgresql driver, but quite a simple
> one to fix (see http://bugzilla.remotesensing.org/show_bug.cgi?id=939).
> I would be happy to commit a fix, and modify/run postgresql unit tests
> to verify the fix, but I'm not sure what sort of review process you like
> to use with GDAL/OGR. So just wondering how you like to run things.
Charlie,
Please feel free to fix this. You are welcome to fix such
obvious bugs with no questionable consequence to the fix
in CVS. If you are at all uncertain about your solution you
ought to drop me a note afterwards so I can look it over.
Stuff like the schema support in the driver requires (I think)
a bit more discussion before you commit any solution.
On review I'm pleased to see that bug 939 isn't one of the
bugs I have ignored for months. I was thinking I ought to
have fixed that when it first cross my desk but I see it is only
20 minutes old or less.
PS. this doesn't really have anything to do with "Maps in PDA"
does it?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
