[Gdal-dev] GDALWarpOperation::WarpRegion
Frank Warmerdam
warmerdam at pobox.com
Thu Sep 29 20:06:09 EDT 2005
On 9/29/05, Sean Forde <sforde at lizardtech.com> wrote:
> The prototype for this function is:
> CPLErr WarpRegion(int nDstXOff, int nDstYOff, int nDstXSize, int
> nDstYSize, int nSrcXOff=0, int nSrcYOff=0, int
> nSrcXSize=0, int nSrcYSize=0)
> Are all these parameters to this function in pixel space? That is, if I
> have spatial coordinates to start with, must I convert them to pixel
> space in order to call this function correctly?
Sean,
The "Dst" values are in pixel space on the destination image, and
the "Src" values are in source image pixel/line coordinates.
Note that normally you would not call WarpRegion(), instead
using ChunkAndWarpImage() which will split the overall region
into more appropriate sized sub-chunks.
If you choose to manage the GDALWarpOperation directly, and
don't want to operate on the whole destination image you will need
to select subwindows in pixel coordinates.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
