[Gdal-dev] build error using Visual Studio 8
Sun Apr 2 20:54:40 EDT 2006
Mateusz Łoskot wrote:
>>> The question is how GDAL should handle it. Should GDAL behave more in C
>>> way or more in C++ way?
>> Mateusz,
>> Well, for the specific case of function like strchr() that have "const
>> correct" versions, I think this just helps us write better code.  We should
>> just review any code with problems, and correct it to work properly with
>> VS8.  In the case of the cpl_strtod.cpp change I took the path of least
>> resistance with the cast because the code is complex and I'm afraid of
>> trying to change too much.
> I understand.
> I just would suggest to avoid using C version of strchr in future.
Mateusz,
I don't see why there is a problem with using strchr()?  Just don't assume
it will return a char * on a const char * argument and things will be ok.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
