[Gdal-dev] gdal_translate image grow
Frank Warmerdam
warmerdam at pobox.com
Mon Apr 3 13:20:29 EDT 2006
Norman Barker wrote:
> Hi,
> I have managed to get this working with VRT raster files, they are
> seriously cool and I can program them from python forming a basic WMS.
> However when I sample from a smaller image to a larger image with
> greater spatial extents I use a kernel filter. It seems that the kernel
> filter doesn't stop in the y-axis and continues for the length of the
> image (see attached).
Norman,
Can you provide me with a .vrt and data file that demonstrate this problem?
Does it happen only with mapserver, or also just doing a gdal_translate from
the .vrt? I suspect a bug in need of fixing.
> Is this something that anyone else has come across? Also how do I make
> the output png have transparent values, I have tried -a_nodata 0?
I think you are supposed to be able to set TRANSPARENT ON in the PNG
outputformat declaration to enable transparency. If you are pulling
from mapserver via WMS there is a TRANSPARENT=ON option that should
turn this on. If this doesn't work let me know the details and I'll see
what I can figure out.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
