[Gdal-dev] ogr2ogr segfaults with large SQL statement
Bruce Raup
brauplists at gmail.com
Wed Apr 5 12:27:54 EDT 2006
Hi Frank,
On 4/4/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> I'm not too sure what version 1.6 is. Perhaps 1.2.6 of GDAL?
I got that number from the libgdal file: "libgdal.so.1.6.0", which I
built and installed on 2005-02-28.
> My understanding of the current logic is that it should list all
> tables and views that have geometry columns in the list of named
> layers. The current query for layers looks like:
> SELECT c.relname FROM pg_class c, geometry_columns g
> WHERE (c.relkind in ('r','v') AND c.relname !~ '^pg'
> AND c.relname::TEXT = g.f_table_name::TEXT)
> Hmm, I see the documentation claims views are not supported. Just
> how does one go about creating a named view in Postgres?
Not supported in what? PostgreSQL? Views are definitely supported in
PostgreSQL. In psql, "\h create" gives (among other things):
Command: CREATE VIEW
Description: define a new view
Syntax:
CREATE [ OR REPLACE ] VIEW name [ ( column_name [, ...] ) ] AS query
Or are you talking about ogr2ogr not supporting views? The old
version (our "1.6") did indeed work for querying PostgreSQL (PostGIS)
views.
> I was going to suggest you use the special datasource syntax
> for listing explicit tables but I see that isn't supported for
> postgres. Perhaps I need to add it.
I don't follow. This is a special syntax for ogr2ogr?
> > - If the WHERE clause in the SQL statement exceeds around 5000
> > characters, it still segfaults.
> I have added a test for large attribute filters, and for large
> SQL statements to the test suite, and identified a serious bug
> which I have corrected. Large attribute filters should now work
> with OGR CVS.
Great! By "large", what do you mean? Is there still a hard limit?
Or does it use a dynamically allocated buffer?
Continued thanks,
Bruce
Bruce Raup
http://cires.colorado.edu/~braup/
