[Gdal-dev] Projection issues with OGR/Proj.4.
Ed McNierney
ed at topozone.com
Fri Apr 7 19:15:57 EDT 2006
Rostic -
It seems that Frank's observation is correct - please see the following
discussion concerning this apparent error in the EPSG database:
http://www.nabble.com/nad27-vs.-epsg-defn-of-CA-State-Plane-zone-VII-t16
6935.html
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Frank
Warmerdam
Sent: Friday, April 07, 2006 7:03 PM
To: Sheykhet, Rostic
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Projection issues with OGR/Proj.4.
Sheykhet, Rostic wrote:
> Hi All,
> I am trying to convert a shape using OGR calls from Lon/Lat to
> California VII State Plane Projection. I get Easting and Northing out
> of it, but when I try to use other tools (ArcMap, OSSIM, Corpscon 6)
> they interpret these easting and northing values to be in a completely
> different place. Here are the values:
> PROJ.4 coordinate system string:
> +proj=lcc +lat_2=34.41666666666666 +lat_1=33.86666666666667
> +lat_0=34.13333333333333 +lon_0=-118.3333333333333
> +x_0=1276106.450596901 +y_0=127079.524511049 +ellps=clrk66
> +datum=NAD27 +to_meter=0.3048006096012192 +no_defs
> Original Lon/Lat: -117.2038, 32.7161
> OGR/Proj.4 Output: 4534220.33, -96890.84
> Other Tools' idea of what easting/northing for this lon/lat should be:
> 4534487.622, 3647093.557
> Other Tools' idea of where OGR/Proj.4-converted easting/northing
> values
> are: -117.324683175, 22.495186883.
> Any suggestions are appreciated.
Rostic,
What WKT .prj file does ArcGIS use for the coordinate system?
I checked an old ArcGIS "26747.prj" and I see that it is using a false
northing of 4160926 feet while the OGR definition for
EPSG:26747 has a false northing of 127079 feet. I'm not sure which is
right but the different might well account for the error.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGF,
http://osgeo.org
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
