[Gdal-dev] Projection issues with OGR/Proj.4.
Sheykhet, Rostic
rsheykhet at sanz.com
Fri Apr 7 19:49:18 EDT 2006
Frank/Ed,
Thanks for the replies. I fixed the projection definition and it works
fine now. For the record, I was not using the proj.4 definitions for
the gdal CSV file, but the stock spatial_ref_sys PostGIS database table.
The definitions were wrong in the table, so caveat emptor.
Thanks again,
Rostic
-----Original Message-----
From: Frank Warmerdam [mailto:fwarmerdam at gmail.com] On Behalf Of Frank
Warmerdam
Sent: Friday, April 07, 2006 5:27 PM
To: Ed McNierney
Cc: Sheykhet, Rostic; gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Projection issues with OGR/Proj.4.
Ed McNierney wrote:
> Rostic -
> It seems that Frank's observation is correct - please see the
following
> discussion concerning this apparent error in the EPSG database:
http://www.nabble.com/nad27-vs.-epsg-defn-of-CA-State-Plane-zone-VII-t16
> 6935.html
> - Ed
Rostic,
I have modified stateplane.csv in gdal/data to point California VII
(NAD27)
to EPSG:26799 instead of the old code. It seems that EPSG corrected
their
database, but the normal way they do this is by deprecating old codes
and
adding a new fixed code. They did this, but I didn't realize it and
hadn't
updated stateplane.csv which is used by the SetStatePlane() method to
turn
a state plane zone into an EPSG code.
With this change the result match the other software output.
*** stateplane.csv.~1.2.~ 2006-02-28 00:19:22.000000000 -0500
--- stateplane.csv 2006-04-07 19:22:34.647688600 -0400
*** 135,141 ****
10404,CALIFORNIA,IV,2,NAD27,404,26744
10405,CALIFORNIA,V,2,NAD27,405,26745
10406,CALIFORNIA,VI,2,NAD27,406,26746
! 10407,CALIFORNIA,VII,2,NAD27,407,26747
10501,COLORADO,NORTH,2,NAD27,501,26753
10502,COLORADO,CENTRAL,2,NAD27,502,26754
10503,COLORADO,SOUTH,2,NAD27,503,26755
--- 135,141 ----
! 10407,CALIFORNIA,VII,2,NAD27,407,26799
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGF,
http://osgeo.org
