[Gdal-dev] RE: need RTTI for OGR (Windows)
Chapman, Martin
MChapman at sanz.com
Tue Apr 11 13:03:00 EDT 2006
Ellen,
Hmmm. I wonder if you could send me your vc++ project? Or at least
send me the line of code where you are doing dynamic_cast. I will try
to compile it on my machine and see if I get a compiler error. If you
send a large zip file, don't send it to the user group...it will get
rejected.
Martin
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of EllenD
Sent: Tuesday, April 11, 2006 5:33 AM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] RE: need RTTI for OGR (Windows)
Martin,
I did set the RTTI property for my Visual Studio project, but that
didn't
work. I compiled GDAL command line and added the /GR option, but that
also
didn't solve the problem. What you state in your reply to Frank's
reply,
seems logic and I also thought it was the case, but unfortunately it
won't
work. I still have no idee on how I can solve my problem.
Ellen
View this message in context:
http://www.nabble.com/need-RTTI-for-OGR-%28Windows%29-t1411792.html#a385
9778
Sent from the GDAL - Dev forum at Nabble.com.
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
