[Gdal-dev] Re: NetCDF.. the world turned upside-down
Frank Warmerdam
warmerdam at pobox.com
Tue Apr 11 15:19:01 EDT 2006
Emilio Mayorga wrote:
> "Reversed" y-axis datasets are quite common in netcdf (Ferret, for
> example, pretty much expects that convention -- or at least it did a
> couple of years ago...). It's not required, but it's probably the
> dominant convention. I think it boils down to the common use of matrix
> math in geophysics; the y-axis is seen as positive-up. Unlike the
> GIS/imagery/"raster" world, where the vertical dimension is
> interpreted as increasing from the top down.
> Having gdal_translate and other gdal utilities interpret flipped
> netcdf y-axis automatically (or providing an optional argument) would
> be very useful.
Emilio,
The normal (and in my opinion proper) process for "upside down" datasets
is for GDAL to associate a geotransform with the dataset that indicates
the orientation. However, I am not adverse to having the netCDF driver
take care of flipping the data internally if Denis would like to address
that. I believe I did do this in the DODS driver since it was otherwise
very hard to exploit the data in most GDAL based applications.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
