[Gdal-dev] apps / MinGW
Frank Warmerdam
warmerdam at pobox.com
Wed Apr 12 09:37:15 EDT 2006
Radim Blazek wrote:
> Hi,
> I found that GDAL applications compiled with MinGW do not
> work correctly because they open binary files in text mode
> and convert CR/LF.
> It can be fixed by
> #ifdef WIN32
> #include <stdlib.h> /* _fmode */
> #include <fcntl.h> /* _O_BINARY */
> #undef _fmode
> int _fmode = _O_BINARY;
> #endif
> Can I add this to the applications in gda/apps?
> See also http://grass.itc.it/pipermail/grass5/2006-February/021066.html
Radim,
Where exactly are you thinking to put this? You refer to gdal/apps,
but the mainline programs in that directly would not normally open
files directly, they would use VSI services. If MinGW builds are using
the Win32 VSI code - as they ought - then I would think this would already
be taken care of.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
