[Gdal-dev] Merging TIFFs
Andrew Larcombe
andrew at andrewlarcombe.co.uk
Wed Apr 12 18:38:13 EDT 2006
Hi all,
I'm after a quick bit of advice before I start coding. I need to write a
small app that will take a 4000x4000 pixel striped geotiff at resolution
x and merge it into a number of larger ~10000x10000 pixel tiled (200px
tile height & width) geotiffs at resolutions y1...yn where y1...yn < x.
Both input and output are in the same projection.
Am I best off using the GDALWarp classes or the
GDALRasterBand->RasteIO() stuff?
TIA,
Andrew
