AW: [Gdal-dev] Building 1.3.1 on Solaris 9 SPARC
H.Porath at hzd.hessen.de
Tue Apr 18 08:26:26 EDT 2006
Hi Christian,
we had the same problem on Solaris 8 SPARC and solved it by inserting "python" in the GDALmake.opt, so it was reading:
BINDINGS = python
Of course you can choose a different "swig"-dir, e.g. perl.
Hope this helps.
Regards
Holger
-----Ursprüngliche Nachricht-----
Von: gdal-dev-bounces at lists.maptools.org [mailto:gdal-dev-bounces at lists.maptools.org] Im Auftrag von Christian Schaffer
Gesendet: Dienstag, 18. April 2006 14:00
An: gdal-dev at lists.maptools.org
Betreff: [Gdal-dev] Building 1.3.1 on Solaris 9 SPARC
Hi List,
using GNU tools, I´m experiencing problems building GDAL on Solaris 9 (SPARC).
Configure runs as expected, but make stops with the following error:
(cd swig; gmake build)
gmake[1]: Entering directory `/ra1/build/gdal-1.3.1/swig'
for dir in ; do (cd $dir; make build ); done
/bin/sh: syntax error at line 1: `;' unexpected
gmake[1]: *** [build] Error 2
gmake[1]: Leaving directory `/ra1/build/gdal-1.3.1/swig'
gmake: *** [swig-target] Error 2
Looking into GDALmake.opt, it says:
# Next Generation SWIG bindings
BINDINGS =
Is there anything, I might be doing the wrong way?
Thanks in advance for helping.
Best regards,
Christian
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060418/100d7094/attachment.html
