[Gdal-dev] Infrastructure developments for GDAL
Mateusz Łoskot
mateusz at loskot.net
Tue Apr 18 14:57:28 EDT 2006
Howard Butler wrote:
> Trac example for GDAL <http://gdal.hobu.net/trac.gdal/> <-- click
> "View Tickets" to see bugs imported from bugzilla and "Browse Source"
> to see the GDAL CVS tree imported into subversion. Trac integrates
> wiki, source code browsing, and bug reporting into one entity. It is
> also relatively straightforward to write your own plugins to Trac to
> do interesting things.
I think it could be interesting to integrate buildbot reports with Trac.
I see a few possible [1] levels of integration:
- simple - Buildbot reports are linked to or presented
directly on Trac pages
- deep - buildbot could run regression tests for every GDAL module and
in case of failures, it could submit a Ticket proposal automatically.
It would better integrate the cycle of
change-build-check-report bug-change, so every issue goes through Trac.
I am not sure if this is a good plan for GDAL project. Simply, just an
idea.
[1] Saying "possible", I don't mean I know such plugins ready to use.
> Buildbot example for GDAL <http://gdal.builds.hobu.net> <-- nightly
> (and on-demand) builds of GDAL for linux, windows, and osx.
Is it possible to generate detailed reports from GDAL unit tests?
As example, here are reports generated for Boost tests:
Summary:
http://boost.sourceforge.net/regression-logs/
Detailed "Developer report":
http://engineering.meta-comm.com/boost-regression/CVS-HEAD/developer/
Example for Boost Array library:
http://engineering.meta-comm.com/boost-regression/CVS-HEAD/developer/array.html
I'm not sure what software Boost uses to run tests but I hope
buildbot allows to write your own test runner to customize reports output.
> Do/will they fit GDAL's development process?
I think so.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
