[Gdal-dev] core dump
Wed Apr 19 15:24:40 EDT 2006
Matt Hanson wrote:
> Ok, there seems to be something with make clean, because it didn't work
> whereas deleting the directory and starting fresh did work, on two
> separate instances.
> Anyway, got gdal installed, then tried running gdalinfo.   Regardless of
> the arguments, it core dumps every time:
> assertion "codecs == NULL" failed: file
> "/usr/src/tiff/tiff-3.7.0beta2/libtiff/tif_compress.c", line 258
> Aborted (core dumped)
> I had installed the latest version of libtiff but it looks like it's
> using some other version.  Suggestions?
Matt,
You might try configuring "--with-libtiff=internal".   Otherwise you may
need to fiddle with the include, and link paths in GDALmake.opt, and
the LD_LIBRARY_PATH environment variable (etc).
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
