[Gdal-dev] building gdal on solaris
Alessandro Amici lists at b-open-solutions.it
Fri Apr 21 03:44:27 EDT 2006
Alle 04:32, venerdì 21 aprile 2006, Peter.Rushforth at statcan.ca ha
scritto:
> (cd .libs && rm -f libgdal.so.1 && ln -s libgdal.so.1.9.0
> libgdal.so.1)
> (cd .libs && rm -f libgdal.so && ln -s libgdal.so.1.9.0 libgdal.so)
> false cru .libs/libgdal.a  ./frmts/o/EnvisatFile.o
> ./frmts/o/_getcell.o ...
apparently there is a problem with the command 'ar' that is not found
('false' is used instead which raises the error).
i would suggest to configure with --without-static if you only use the
dynalic library libgdal.so.
as said by Frank, --without-libtool is another possibility.
cheers,
alessandro
B-Open Solutions srl - http://www.bopen.it/ - http://www.bopen.eu/
