[Gdal-dev] GEOCCS - Geocentric CS in OGR?
Craig Miller
craig.miller at spatialminds.com
Sat Apr 22 00:41:58 EDT 2006
I'm working throught the WKT spec in the SF COM document and it lists three
categories of SRSs:
Geographic - GOEGCS
Projected - PROJCS
Geocentric - GEOCCS
>From what I can tell OGR has three categories too:
Geographic => IsGeographic() - GEOGCS
Projected => IsProjected() - PROJCS
Local => IsLocal() - LOCALCS or LOCAL_CS (according to OGR docs)
With this in mind...
- How are geocentric coordinate systems represented in OGR?
- If GEOCCS is supported, why isn't there a IsGeocentric() method?
- Is OGR the only product that supports the LOCALCS object?
- Is it LOCALCS or LOCAL_CS?
Thanks for the help, :-)
Craig
