[Gdal-dev] Very very newbie lost with gdalwarp
Frank Warmerdam
warmerdam at pobox.com
Thu Apr 27 11:20:04 EDT 2006
Steve Alexander wrote:
> I apologize for my ignorance up front. I am very, very new to this and
> am attempting to convert a BigJPG from USAPhotomats as references here:
> http://www.msh-tools.com/general.html Under the “Convert from UTM to
> WGS84 Lat/Long” heading.
> I have to tell you I am LOST. As I stated earlier am so new to this it
> is pathetic. Basically I am trying to convert a JPG to use in Ozi
> Explorer to trace a trailmap to download to my Magellan Explorist 600
> GPS like is shown here: http://www.msh-tools.com/addmagmap/ex4.html
> I want to trace an aerial photo trail map, make a new detailed map and
> upload it to my GPS. I am stuck when it comes to using gdalwarp to
> adjust the picture and convert the coordinates. I have tried it but I
> keep getting errors.
> Can anyone just point me in the right direction. (Especially what
> command line switches I should use with gdalwarp)????
Steve,
If your source file has a world file (.jgw) and is in UTM 18 (as in the
web page example) then you would do something like:
gdalwarp -of BMP in.jpg out.bmp \
-s_srs '+proj=utm +zone=18 +datum=WGS84' +t_srs WGS84
Good luck,
and watch the world go round - Rush | President OSGF, http://osgeo.org
