[Gdal-dev] Building on Windows
Matt Hanson
mhanson at photon.com
Tue Aug 1 11:06:32 EDT 2006
Norman, thanks. I think I did the right thing. cpl_config is automatically generated so I thought I needed to change the defines (HAVE_VPRINTF, HAVE_VSNPRINTF, and HAVE_SNPRINTF) to 0's in cpl_config.h.vc. I don't understand why these functions aren't defined in the MSVC compilers but whatever.
Things compiled find but then got a linking error, anyone come across this?
ogrsf_frmts.lib(parsexsd.obj) : warning LNK4221: no public symbols found; archive member will be inaccessible
link /dll /debug /INCLUDE:_OGRFeatureStylePuller /INCLUDE:_OSRValidate /INCLUDE:_OPTGetProjectionMethods /INCLUDE:_OGR_G_GetPointCount /INCLUDE:_OGRRegisterAll /INCLUDE:_GDALSimpleImageWarp at 36 /INCLUDE:_GDALReprojectImage at 48 /INCLUDE:_GDALComputeMedianCutPCT at 32 /INCLUDE:_GDALDitherRGB2PCT at 28 /INCLUDE:_vbSafeArrayToPtr at 16 /INCLUDE:_OCTNewCoordinateTransformation at 8 port\*.obj gcore\*.obj alg\*.obj frmts\o\*.obj ogr\ogrsf_frmts\ogrsf_frmts.lib ogr\ogr.lib vb6\vb6_support.obj odbc32.lib gcore\Version.res /out:gdal13.dll /implib:gdal_i.lib
/usr/bin/link: too many arguments
Try `/usr/bin/link --help' for more information.
NMAKE : fatal error U1077: 'C:\cygwin\bin\link.EXE' : return code '0x1'
Stop.
Sent: Tue 8/1/2006 4:04 AM
To: Matt Hanson; gdal-dev at lists.maptools.org
Subject: RE: [Gdal-dev] Building on Windows
From: gdal-dev-bounces at lists.maptools.org [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Matt Hanson
Sent: Monday, July 31, 2006 8:54 PM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] Building on Windows
I'm trying to compile GDAL using the provided makefile.vc files, and I get the same error right at the beginning. In doing some google searches I found some posts in the GDAL archive from some chap that had the same problem a couple years ago....that chap turned out to be me! However, back then I did resolve the issue somehow, but it wasn't resolved with any list help so there's no record of what I did. This is a different computer, and the newest version of Visual Studio so the fact that I'm the only one to ever have this problem I find rather surprising. Anyway any suggestions to help me remember what I did?
Much thanks! Here's the error:
$ nmake -f makefile.vc
Microsoft (R) Program Maintenance Utility Version 8.00.50727.42
Copyright (C) Microsoft Corporation. All rights reserved.
cd port
nmake /nologo /f makefile.vc
cl /nologo /MD /EHsc /Zi /Fd..\gdal.pdb -I..\port -I..\ogr -I..\gcore -I..\alg /c cpl_conv.cpp
cpl_conv.cpp
cpl_conv.cpp(1313) : error C3861: 'snprintf': identifier not found
NMAKE : fatal error U1077: '"c:\Program Files\Microsoft Visual Studio 8\VC\BIN\cl.EXE"' : return code '0x2'
Stop.
NMAKE : fatal error U1077: '"c:\Program Files\Microsoft Visual Studio 8\VC\BIN\nmake.EXE"' : return code '0x2'
Stop.
Matt
Hi Matt,
Theres is a thread on snprintf problems here - http://groups.google.co.uk/group/microsoft.public.vc.language/browse_thread/thread/32d833e0d1d517af/6021c0870b230253%236021c0870b230253
And in port/cpl_config.h there are already
#define vsnprintf _vsnprintf
#define snprintf _snprintf
I have just compiled GDAL with MSVC 8, you need to install the windows SDK as well if you are using the free version.
Norman
