[Gdal-dev] Re: Fwd: gdal swig interface Band.i Updated
Charlie Savage
cfis at savagexi.com
Sat Aug 5 18:28:23 EDT 2006
Hmm, in theory %apply and OUT do the same thing. Once again, see:
http://www.swig.org/Doc1.3/Arguments.html#Arguments_nn5
Anyway, I would take the simple approach, which is add this line:
%include "typemaps.i"
To gdal.i before line 441 which is:
%include "Band.i"
And in fact, I'd probably put it on line 192 (before the #if
defined(SWIGPYTHON).
Doing that simplifies the problem. If it doesn't work, then yes, it
appears the OUTPUT * parameter is not working for Java in which case go
back to using apply (and maybe submit a bug to SWIG).
However, if you use %apply then you should also clear it after the
method is defined.
%apply (int *OUTPUT){int *blockXSize, int *blockYSize}
void GetBlockSize(int *blockXSize, int *blockYSize){
GDALGetBlockSize(self, blockXSize, blockYSize);
%clear (int *blockXSize, int *blockYSize)
Its probably not that important in this case, but if there happened to
be another method with the same 2 output parameters then this typemap
would be applied again (sometimes you want that, sometimes you don't).
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060805/b761c123/smime.bin
