[Gdal-dev] Re: Fwd: gdal swig interface Band.i Updated
Thu Aug 17 11:14:39 EDT 2006
Daniele Romagnoli wrote:
> Dear Mr. Warmerdam,
> Thank you for the update.
> I quote here an useful comment of Mr. Charlie Savage.
> Mr. Charlie Savage wrote:
> However, if you use %apply then you should also clear it after the
> method is defined.
> %apply (int *OUTPUT){int *blockXSize, int *blockYSize}
>   void GetBlockSize(int *blockXSize, int *blockYSize){
>               GDALGetBlockSize(self, blockXSize, blockYSize);
> %clear (int *blockXSize, int *blockYSize);
> Its probably not that important in this case, but if there happened to
> be another method with the same 2 output parameters then this typemap
> would be applied again (sometimes you want that, sometimes you don't).
Daniel,
That's why I changed the parameter names to pnBlockXSize and pnBlockYSize
since anything using the prefix pn would mean the arguments are pointers to
single integer values and the applied OUTPUT logic would presumably apply.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
