[Gdal-dev] ECW compression - Extremely slow Linux performance
Andrew Larcombe
andrew at andrewlarcombe.co.uk
Mon Aug 21 04:43:52 EDT 2006
Frank Warmerdam wrote:
> Andrew Larcombe wrote:
>> Frank - according to top the CPU usage varies but never gets above
>> 20%. Does this shed any more light on the issue?
> Andrew,
> This indicates things are stalling somewhere. My guess then is that it
> is a thread switching issue of some sort. How confident are you that
> you are using the latest and greatest ECW SDK?
> It could also be some sort of IO problem. I think the encoder keeps
> temp files in /tmp. I trust that is a fast local disk too?
> Beyond that it gets pretty involved to try and diagnose. I just hate
> multithreaded libraries.
Frank,
Yes /tmp is a fast local disk too. I'm using the latest source ECW SDK -
3.3RC2. I note there is a 3.3 final release, but these are Windows binaries.
strace'ing gdal_translate gives this:
% time seconds usecs/call calls errors syscall
35.14 0.357212 14 26030 write
24.54 0.249446 9 26948 sched_yield
18.41 0.187088 7 25948 gettimeofday
9.42 0.095770 17 5505 nanosleep
7.40 0.075248 6 12238 _llseek
1.68 0.017050 11 1576 1 read
1.64 0.016643 65 257 munmap
0.46 0.004717 15 317 mprotect
0.32 0.003283 657 5 unlink
0.29 0.002901 24 119 brk
0.23 0.002337 9 264 mmap2
0.13 0.001281 16 81 25 open
0.09 0.000914 14 65 old_mmap
0.06 0.000572 10 56 close
0.06 0.000566 9 64 fstat64
0.05 0.000463 10 46 21 stat64
0.03 0.000289 58 5 5 lstat64
0.02 0.000213 11 19 3 futex
0.02 0.000172 172 1 execve
0.01 0.000084 17 5 clone
0.00 0.000033 17 2 tgkill
0.00 0.000027 9 3 sched_getparam
0.00 0.000026 9 3 sched_getscheduler
0.00 0.000023 12 2 getrlimit
0.00 0.000014 3 5 getpid
0.00 0.000014 14 1 set_thread_area
0.00 0.000013 13 1 rt_sigaction
0.00 0.000011 11 1 rt_sigprocmask
0.00 0.000011 11 1 set_tid_address
0.00 0.000004 4 1 uname
100.00 1.016425 99569 55 total
Do you have any more thoughts on this, or where the problem could lie?
It does seem to be making an awfully large number of gettimeofday calls,
although maybe this is a red herring?
Regards,
Andrew
Andrew Larcombe
