[Gdal-dev] Re: How to get configuration options
Frank Warmerdam
warmerdam at pobox.com
Mon Aug 21 13:04:25 EDT 2006
Daniele Romagnoli wrote:
> Hi list,
> I have another stupid question for you :)
> I'm using Java and I'm trying to detect if GDAL is using CACHE.
> Which is the right way to use gdal.GetConfigOption(String, String)?
> I'have tried:
> String useCache = gdal.GetConfigOption("GDAL_FORCE_CACHING", null);
> It returns null;
> I'have tried:
> String useCache = gdal.GetConfigOption("GDAL_FORCE_CACHING", "");
> It returns null;
> I'have tried:
> String useCache = gdal.GetConfigOption("GDAL_FORCE_CACHING", "Hello!");
> It returns "Hello!".
> Where am I wrong?
Daniele,
Config options are something that can be set by the user or application
and normally there are none set in which case GDAL uses it's internal
defaults for config based decisions. So the fact that you get "Hello!"
back just means that this config options is not set.
Currently the default behavior is to treat GDAL_FORCE_CACHING as NO if
it is not set, so you should likely use that as your default.
Be forewarned that a variety of values are legal (true, false, yes, no,
1, 0, on, off).
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
