[Gdal-dev] Complex Data Types
Matt Hanson
mhanson at photon.com
Wed Aug 23 09:39:43 EDT 2006
Ok, so if I defined my own complex structure
struct CInt16 {
int16 real;
int16 imag;
and declare a pointer for a 100x100 section:
CInt16 *cbuff = new CInt16[100*100]
I *think* I should be able to pass this to RasterIO using the GDT_CInt16 type, correct?
-matt
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Tue 8/22/2006 3:24 PM
To: Matt Hanson
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Complex Data Types
Matt Hanson wrote:
> I'm a little confused with regard to GDAL's handling of complex data
> types. As there is no built in complex types for C++ what is RasterIO
> expecting as a buffer type when using the GDT_C* data types? Would it
> simply be a pointer of twice the normal length?
Matt,
Essentially the complex data types are passed around as pairs of the
basic data type. So an array of GDT_CInt16 would be an array of GInt16's
but with two values (real followed by imaginary) for each value.
So, the answer to your question is "yes".
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org <http://osgeo.org/>
