[Gdal-dev] Re: [Shapelib] shapelib.dll in a Pocket PC
Mateusz Loskot mateusz at loskot.net
Thu Aug 24 15:41:44 EDT 2006
Daniel de la Cuesta wrote:
> First of all, thank you for your response. I have done what you say and
> I have added the sources of http://mateusz.loskot.net/tmp/shapelibce.zip
> to my dll Project but when I build the solution i get the following error:
> fatal error C1010: unexpected end of file while looking for precompiled
> header. Did you forget to add '#include "stdafx.h"' to your source?
Daniel.
I suppose you created DLL project with precompiled headers support.
Go to project properties dialog box and next to precompiled headers
select to not to use precompiled headers in the DLL project.
> I am using VS 2005. Maybe it doesn´t support C code.
VS  = Visual Studio but this si a bunch of compilers: C#, VB, VC++, etc.
So, I'm not sure I understand the problem here.
> Do I have to use a
> previous version os VS to generate de .dll for Pocket Pc?
You need to use Visual C++ compiler in version 6.0 or any above,
7.0, 7.1 or 8.0
Cheers
Mateusz Loskot
