[Gdal-dev] VSI file open/close issue
Frederic Claudel
frederic.claudel at magellium.fr
Fri Aug 25 09:03:31 EDT 2006
When using VSI* or VSI*L functions, it seems impossible to mix both, which
means opening a file using VSIFOpen then closing it with VSIFCloseL.
Hence my question : how can I tell them apart ? In a new GDAL driver where I
need to open lots of datasets, I'd like to re-use the opened file descriptor
included in GDALOpenInfo to avoid unnecessary IO.
But that file descriptor can be opened by either of VSIFOpen or VSIFOpenL
(when VSIFOpen fails) - by the way it's always closed using VSIFClose
Should I use a RTTI function to guess the actual type?
Thanks,
Frederic Claudel
-----Message d'origine-----
De : gdal-dev-bounces at lists.maptools.org
[mailto:gdal-dev-bounces at lists.maptools.org] De la part de Shaun Kolomeitz
Envoyé : vendredi 25 août 2006 01:04
À : Frank Warmerdam
Cc : gdal-dev at lists.maptools.org
Objet : RE: [Gdal-dev] GDAL and Solaris 10/sparc
Thanks Frank,
I had a quick look at getting the IRC client to go, but our work proxy can
be a bit difficult to get around.
I will have a look at getting access via SSH, again this is usually not
permitted because of security concerns. Perhaps if I could give them a
specific client address, and then decide on a time window to allow you
"through" our firewall we could have more success.
I suspect that we have everything needed to do a successful build, but I am
not entirely sure of what order things should be in. The 32 vs 64 bit build
is puzzling me as to which PATH and LD_LIBRARY settings are needed plus
which system wide settings should apply.
I've had success in the past in building ECW as a separate (standalone)
entity, but not in getting it to link-in with GDAL. I've also managed to get
an older version of GDAL (v1.2) working. Bugger me if I can remember how I
did it now !
I'll contact our network people and see if I can get access via SSH granted.
Regards,
Shaun
> -----Original Message-----
> From: Frank Warmerdam [mailto:warmerdam at pobox.com]
> Sent: Friday, 25 August 2006 1:17 AM
> To: Shaun Kolomeitz
> Cc: gdal-dev at lists.maptools.org
> Subject: Re: [Gdal-dev] GDAL and Solaris 10/sparc
> Shaun Kolomeitz wrote:
> > After months of searching, hacking and many hundreds of
> compile attempts I am still unable to successfully get GDAL
> to compile on a SPARC/Solaris 10 environment. No amount of
> searching lists and getting obscure possible fixes has worked.
> > My original aim was to get GDAL with ECW compiled and
> going, but for now I'd even settle for just Geotiff, HFA and
> JPEG. I'll just have to use WindoZe to do any other conversions.
> > Would someone mind sending me some settings from their
> working GDAL sparc/Solaris X configurations ?
> > Stuff like the system wide "crle", PATH and LD_LIBRARY_PATH
> settings for compilation and the versions of GCC/etc that
> actually work.
> > Any other suggestions that might help me get this going
> would be most welcome.
> Shaun,
> Perhaps it would be best to try and meet in IRC (#gdal on
> irc.freenode.net)
> to try and debug your build problems on Solaris.
> Alternatively, if you can
> provide temporary ssh access to me, I could likely build it.
> I don't think there should be any great difficulty in
> building on Solaris
> as long as reasonably functional tool chain is available. I
> would hesitate
> to take on building the ECW libraries there though. I'm sure
> it is possible,
> but perhaps not easy.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo,
http://osgeo.org
___________________________
Disclaimer
This e-mail, including attachments if any, has originated from a Queensland
government agency and may contain information that is confidential, or
covered by legal professional privilege, and is intended for the named
recipient(s) only. If you have received this message in error, you are
asked to inform the sender as quickly as possible and delete this message
and any copies of this message from your computer system network.
Any form of disclosure, modification, distribution and/or publication of
this e-mail, including attachments is prohibited. Unless otherwise stated,
this e-mail, including attachments represents the views of the sender and
not the views of the Environmental Protection Agency.
Although this e-mail has been checked for the presence of computer viruses,
the Environmental Protection Agency provides no warranty that all possible
viruses have been detected and cleaned. Any use of this e-mail could harm
your computer system.
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
