[Gdal-dev] ogr2ogr : creating Multipolygones shapefiles from
Postgis
Marc Jacquin
marc.jacquin at magellium.fr
Fri Dec 1 07:22:22 EST 2006
Hi all,
For example this works fine for polygons:
Ogr2ogr -f "ESRI Shapefile" d:/test.shp PG:"dbname=xxxx user=xxx host=xxx
password=xxx port=xxx" -sql "select the_geom from mytable where .... "
If you use it with a multipolygon PostGIS geometry, it creates an empty Line
shapefile.
I could get around by using the where clause instead of the sql clause:
password=xxx port=xxx" mytable -where "...."
Should I file a bug?
I use the binary version of FWTools 1.10.
Regards,
Marc
