[Gdal-dev] Build csharp swig (from real newbie)
Alan
alankeown at southernphone.com.au
Mon Dec 4 02:12:53 EST 2006
Dear List,
Using today's CVS, I've built the gdal13.dll (thanks to Howard)
And run nmake with the interface option at /swig/csharp/
When I run nmake -f makefile.vc using the MSVC 2003 nmake I get the
following error:
ogr\Geometry.cs(45,1): error CS1519: Invalid token '{' in class, struct, or
interface member declaration
It turns out there is a stray "{}" pair in the ogr\Geometry.cs file
surrounding
public int ExportToWkb( byte[] buffer, int byte_order )
and
public int ExportToWkb( byte[] buffer )
If I edit the ogr\Geometry.cs file I get an error at
gdal\Band.cs(17,58): error CS1525: Invalid expression term ''
gdal\Band.cs(17,59): error CS1026: ) expected
gdal\Band.cs(19,4): error CS1513: } expected
gdal\Band.cs(40,1): error CS1519: Invalid token '{' in class, struct, or
Could someone tell me if I'm doing something wrong?
Thanks
AlanK
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061204/07e2831b/attachment.html
