[Gdal-dev] Need Help with ogr2ogr Import Shapefile Error
Bill Thoen
bthoen at gisnet.com
Mon Dec 4 13:38:49 EST 2006
On Mon, Dec 04, 2006 at 10:11:18AM -0800, Frances Collier wrote:
> After running the ogr2ogr command, it created a table, correct? What's the
> geometry of the table? I've had this problem before and it was because the
> "enforce_geotype_wkb_geometry" was set to "Polygon". I had to change the
> table to "enforce_geotype_wkb_geometry=multipolygon".
That seems to be the problem. I recreated the database and loaded the table
again (but this time I used the -nlt switch set to MULTIPOLYGON) and it
looks like it loaded without errors.
But now I can't access the table! Is there something about this table name
it doesn't like? Why can't I display the table structure or select anything
from this table?
(BTW, notice that it uses lowercase letters in one of the error messages,
but not both.)
clu=# \d
List of relations
Schema | Name | Type | Owner
public | clu_001ilna04_U | table | bthoen
public | clu_001ilna04_U_ogc_fid_seq | sequence | bthoen
public | geometry_columns | table | bthoen
public | spatial_ref_sys | table | bthoen
(4 rows)
clu=# \d clu_001ilna04_U
Did not find any relation named "clu_001ilna04_U".
clu=# select * from clu_001ilna04_U;
ERROR: relation "clu_001ilna04_u" does not exist
clu=#
