[Gdal-dev] Any possibility of static compile?
Collins, Benjamin
collinsb at mitre.org
Mon Dec 4 14:21:13 EST 2006
>From my experience with the Java bindings, this is also possible with
the SWIG bindings. For Java this means stand-alone JNI libraries that
include GDAL statically linked internally. It can be achieved in much
the same way; by linking against libgdal.a
I have had success on Win32, Linux, and OSX (PPC + Intel)
Ben
>-----Original Message-----
>From: gdal-dev-bounces at lists.maptools.org
>[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of
>Frank Warmerdam
>Sent: Monday, December 04, 2006 12:46 PM
>To: Curt Mills
>Cc: gdal-dev at lists.maptools.org
>Subject: Re: [Gdal-dev] Any possibility of static compile?
>Curt Mills wrote:
>> I need to do a static compile of my app. I've been able to compile
>> Shapelib, proj, geotiff, and a few other libraries statically so
>> far.
>> I'd like to get GDAL compiled in, of which we use some of the OGR
>> functions, but I recall reading earlier about some problems with
>> static compiles of GDAL. Is there a way to get OGR or the full
>> GDAL/OGR library compiled statically these days?
>> There's also a way under Linux Standard Base rules to distribute a
>> shared library along with the application, so that's my backup plan.
>> I'd much rather distribute the entire thing statically linked if
>> possible though. Any hope?
>Curt,
>John pointed out some of the issues. For what it is worth, I was able
>to issue the following command against my local GDAL build:
> gcc -Ibld/include gdal/apps/gdalinfo.c gdal/libgdal.a
>-L/usr/local/lib -lgeos
>-lgeos_c -L/usr/local/lib -lxerces-c -lpthread -lNCSEcw
>-lNCSCnet -lNCSUtil
>-L/home/warmerda/pkg/HDF4.2r1/NewHDF/lib -lmfhdf -ldf -ljpeg
>-ltiff -lpng -lpq
>-L/usr/lib/postgresql/8.0/lib -lpq -lz -lpthread -lm -lrt -ldl
>-L/home/warmerda/pkg/kakadu-5.1/lib -lkdu -lsqlite3 -L/usr/lib
>-lcurl -lidn
>-lssl -lcrypto -ldl -lssl -lcrypto -ldl -lz -L/usr/lib
>-lmysqlclient -lz
>-lcrypt -lnsl -lm -o gdalinfo
>This produced a gdalinfo executable with GDAL statically
>linked in, though
>the various support libraries were still .so's. I did this by
>configuring
>GDAL "--without-libtool" and then linking against
>gdal/libgdal.a. Essentially
>I took the build's "gdal-config --libs" output replaced the
>part about -lgdal
>itself with the path to libgdal.a, and used the rest unchanged.
>So, one data point says static builds are doable.
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam,
>warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | President OSGeo,
>http://osgeo.org
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/gdal-dev
