[Gdal-dev] Compiling under Linux Standard Base
Frank Warmerdam
warmerdam at pobox.com
Thu Dec 7 16:27:23 EST 2006
Curt, WE7U wrote:
> I'm having difficulties in disabling some of the options in GDAL via
> configure. For instance these don't appear to work:
> --without-libtiff
> --without-geotiff
> If I try to disable libtiff, configure picks it up from the system.
> I don't want to use the external library instead of the internal, I
> want it disabled entirely.
> If I try to disable geotiff configure bombs out before completing.
> If I specify "/opt/lsb/lib" as the directory configure isn't seeing
> it even though libgeotiff.a is there.
Curt,
You might want to file a bug on this. I don't think I've ever tried
to build without tiff support, and I think it would be somewhat
challenging, since a few other drivers and parts of OGRSpatialReference
depend on bits of libgeotiff.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
