[Gdal-dev] Fwd: Gdal-dev Digest, Vol 31, Issue 22
Alejandro Silva
alejandro.silva.a at gmail.com
Sun Dec 10 21:18:24 EST 2006
---------- Forwarded message ----------
gdal-dev-request at lists.maptools.org>
Date: 10-dic-2006 18:02
Subject: Gdal-dev Digest, Vol 31, Issue 22
To: gdal-dev at lists.maptools.org
Send Gdal-dev mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.maptools.org/mailman/listinfo/gdal-dev
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
gdal-dev-owner at lists.maptools.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Gdal-dev digest..."
Today's Topics:
1. Re: ogr2ogr Default Output SRS (Martin Spott)
2. Re: ogr2ogr Default Output SRS (Frank Warmerdam)
Message: 1
Date: Sat, 9 Dec 2006 19:15:43 +0000 (UTC)
Subject: Re: [Gdal-dev] ogr2ogr Default Output SRS
Message-ID: <elf20v$oag$1 at osprey.mgras.de>
Hi Frank, thanks for responding,
Frank Warmerdam wrote:
> There are some "sensitivities" in how ogr2ogr identifies which SRID to use
> in postgis. If it doesn't find a match then it creates a new SRID at the
> "top" of the table, which I suspect did for the 32767 case.
> It may be that the spatial_ref_sys tables in your different versions of
> postgis are slightly different in the formatting of the WKT entries and
> this is in one SRID 4326 gets used and in the other it doesn't.
But what can a user actually do about this, whose "fault" is it if
'ogr2ogr' and PostGIS don't place together nicely, and, which I
consider even more important, which route to take to solve this issue ?
Apparently PostGIS started shipping newer versions of the
spatial_ref_sys table with 1.1.6 and 'ogr2ogr' somehow doesn't 'agree'
with the contents of this table.
I just ran a test with PostGIS-1.2.0 - same effect as with 1.1.6, still
using the respective spatial_ref_sys that comes with the very PostGIS
release. I then pushed the contents of the spatial_ref_sys table from
PostGIS-1.1.5 into the DB, still running PostGIS-1.2.0, and everything
is fine. So, is this sort of a bug in 'ogr2ogr' that shows some
incapability to handle newer EPSG declarations or is this to be
considered as a misfeature in the recent EPSG files that breaks
'ogr2ogr' ?
Cheerio,
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
Message: 2
Date: Sun, 10 Dec 2006 00:24:34 -0500
To: Martin.Spott at mgras.net
Cc: gdal-dev at lists.maptools.org
Message-ID: <457B9A12.6080906 at pobox.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
use
Martin,
Normally there is no great harm in creating a new SRID for what is a
slightly different formatting of a coordinate system that from a
meaningful point of view matches an existing SRID.
However, the solution, I think would be for OGR to:
o Do the search based on the proj.4 string rather than the WKT.
The proj.4 strings are less likely to suffer from formatting
variations over time.
o Provide a mechanism (a layer creation option for instance) so
that the user can force use of a particular SRID whether OGR
thinks the coordinate systems match or not.
> 'ogr2ogr' ?
Note that the spatial_ref_sys for PostGIS is generated with OGR. So
there is no reason to believe the newer spatial_ref_sys will differ
from what newer OGR versions expect. Upgrading GDAL/OGR may therefore
help.
Generally speaking comparing coordinate systems is *hard*. Especially if
you wish to do so efficiently.
If you file a bug against OGR with the two earlier suggestions, I'll try
and have them implemented at some point. Ideally in time for the GDAL
1.4.0 release.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGeo, http://osgeo.org
Gdal-dev at lists.maptools.org
End of Gdal-dev Digest, Vol 31, Issue 22
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061211/6c07d66b/attachment.html
