[Gdal-dev] Building GDAL with GEOS in Unix
Elavazhagan.M elavazhagan.mouniandy at kcubeconsulting.com
Thu Dec 14 23:18:04 EST 2006
I have already posted this question to 'GEOS-Dev'. Since I thought this is
the most relevant place to get help from I am posting it again here.
Can anyone please guide me how to enable GEOS Support in GDAL (Unix)? I have
installed Geos 3.0.0rc2 in my system and configured GDAL 1.32 with the
following commands:
"./configure -with-geos=yes". This did not work so I tried with "./configure
--with-geos=/root/usr/bin/geos-config" also.
Although these commands worked well and I successfully installed GDAL, when
I run the command "ogr2ogr", it gives the following error message:
"ERROR 6: Geos support not enabled"
Do I need to change anything in the makefiles of GDAL?
Please help me to resolve this issue.
Thank you.
Regards,
Elavazhagan.M
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061215/1a9c7394/attachment.html
