[Gdal-dev] Memory leak? How to release GDAL datasets?
Frank Warmerdam
warmerdam at pobox.com
Fri Dec 15 01:49:44 EST 2006
On 12/13/06, Craig Miller <craig.miller at spatialminds.com> wrote:
> Is GDALClose(m_pDataset) the only method that needs to be called after
> opening a GDAL datset?
Craig,
That should be sufficient.
I really can't think why there would be any polygon geometry
creation going on to open a geotiff file. I wonder if you might be
getting some sort of false report from your memory tester.
If you can point me to a file that demonstrates the problem,
I could try testing it under valgrind using something like
gdalinfo.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
